$i18n{business.forBusiness}
How to Find the Right Internal SSD for You
Not sure which SSD fits your system? Start with compatibility, then compare options based on how you use your device.
Compatibility and Performance: NVMe vs. SATA
Internal SSDs are not one‑size‑fits‑all. The right choice depends on what your system supports and how you plan to use it. See the comparison information below to learn about the difference between NVMe™ vs. SATA.
Internal NVMe SSDs
NVMe SSDs connect over the PCIe interface and are typically installed in M.2 slots on motherboards. They deliver fast read/write speeds and low latency for performance‑driven workloads.
Ideal for:
- Gaming PCs
- Content creation
- High‑performance desktops/laptops
- PCIe Gen 3, Gen 4, or Gen 5 capable systems
| SANDISK Optimus™ GX PRO 8100 SSD Shop Now |
SANDISK Optimus™ GX PRO 850X SSD Shop Now |
SANDISK Optimus™ GX 7100 SSD Shop Now |
| Capacity2 | 1TB, 2TB, 4TB, 8TB2 | 1TB, 2TB, 4TB, 8TB2 | 500GB, 1TB, 2TB, 4TB2 |
| Interface | PCIe® 5.0 | PCIe® 4.0 | PCIe® 4.0 |
| Sequential Read1 (up to) | 14,900MB/s1 | 7,300MB/s1 (1TB, 2TB, and 4TB models) | 7,250MB/s1 (1TB and 2TB models) |
| Sequential Write1 (up to) | 14,000MB/s1 (2TB and 4TB models) | 6,600MB/s1 (2TB, 4TB, and 8TB models) | 6,900MB/s1 (1TB and 2TB models) |
Frequently Asked Questions About Internal SSDs
Related Content
1. 1 MB/s = 1 million bytes per second. Based on internal testing; performance may vary depending upon host device, usage conditions, drive capacity, and other factors.
2. 1GB=1,000,000,000 bytes. 1TB=1,000,000,000,000 bytes. Actual user storage less.
3. Product: WD Red™ SN700 NVMe™ SSD
