Discover NVMe™
Faster data transfer, lower latency, next-gen performance — NVMe is the future of solid state flash storage for productivity, gaming, data centers, and more.
Why Choose NVMe?
High bandwidth
Up to 4000MB/s per lane — with up to four lanes per device.
Low latency
Help maximize efficiency and process data faster with up to 64K commands per queue.
Scalability
Do more with less, with performance that increases at higher capacities.
Learn More About NVMe Internal SSDs
NVMe – oder „Non-Volatile Memory Express“ – ist ein Speicher- und Übertragungsprotokoll, das sich als Standard für Solid-State-Drives (SSDs) weit verbreitet hat. NVMe-SSDs bieten eine höhere Leistung und geringere Latenz als ältere Protokolle und eignen sich daher ideal für rechenintensive Einsatzbereiche wie kreative Anwendungen, PC- und Konsolenspiele sowie Rechenzentren in Unternehmen.
What You Can Do with NVMe
NVMe SSDs for Personal Use
Boost productivity at home and professional output at work with a drive that won’t keep you waiting.
Faster Everyday Performance
Upgrade your PC with PCIe® 4.0 speeds for quicker startups, faster file saves, and smoother multitasking.
More Space for What Matters
Store photos, videos, games, and creative projects with up to 4TB1 of capacity with the SANDISK Optimus™ 5100 NVMe™ SSD.
Power That Keeps Up
Get high performance with less power consumption, so your laptop runs faster for longer.
NVMe SSDs for Gaming
Call in NVMe backup to supercharge your next gaming session, whether you’re a PC or console gamer.
Ultra-Fast Load Times
Stop wasting time on load screens and get into the game fast.
Blazing-Fast PCIe 5.0 Performance
Expanded Storage
Keep more games at the ready with a range of capacities up to 8TB1 for select models.
NVMe SSDs for Data Center
Accelerate your applications and unlock new possibilities with ultra-high-performance NVMe technology.
High-Capacity Performance
Accelerate data-intensive applications with UltraQLC™ technology and BiCS8 NAND.
Scalable, AI-Ready Architecture
Support AI data cycles on a scalable platform built for next-generation workloads.
Enterprise-Grade Reliability
Help protect critical data with advanced features, including power loss protection, end-to-end data protection, and enterprise-class security.
Ähnliche Inhalte
1. Capacity disclaimer: 1GB = 1 billion bytes and 1TB = 1 trillion bytes. Actual user capacity may be less depending on operating environment and RAID configuration (if applicable).
2. Speeds vary by product and capacity. 1MB/s = 1 million bytes per second. Based on internal testing; performance may vary depending upon host device, usage conditions, drive capacity, and other factors.
