Compare Internal SSDs for PCs and Laptops
Upgrading to an internal SSD is one of the fastest ways to improve system performance, delivering faster boot times, quicker app launches, and smoother multitasking compared to traditional hard drives.
Compatibility and Performance: NVMe vs. SATA
Internal SSDs are not one‑size‑fits‑all. The right choice depends on what your system supports and how you plan to use it. See the comparison information below to learn about the difference between NVMe™ vs. SATA.
Internal NVMe™ SSDs
NVMe SSDs connect over the PCIe interface and are typically installed in M.2 slots on motherboards. They deliver fast read/write speeds and low latency for performance‑driven workloads.
Ideal for:
  • Gaming PCs
  • Content creation
  • High‑performance desktops/laptops
  • PCIe Gen 3, Gen 4, or Gen 5 capable systems
Internal SATA SSDs
SATA SSDs use the same interface as traditional hard drives and are commonly available in 2.5‑inch form factor, with some M.2 SATA options. They offer a simple, widely compatible upgrade path.
Ideal for:
  • Replacing a hard drive
  • Adding secondary storage
  • Everyday computing and productivity
  • Upgrading legacy desktop and laptops
Enhance Gaming Experiences with Faster Internal SSD Storage
Load into games fast
High‑performance internal SSDs deliver ultra‑fast sequential read/write speeds of up to 14,900/14,000 MB/s1 (2TB and 4TB models2) on select models — which means you can launch your favorite titles quicker, with smoother loads for expansive game worlds.
Play longer with confidence.
Built for demanding gaming workloads, internal SSDs offer strong endurance to handle frequent installs, updates, and extended play sessions without compromising performance.
Store more of what you play.
High‑capacity options for internal SSDs make it easy to keep large game libraries, ongoing updates, and future releases all in one place, reducing the need to manage or delete content.
  SANDISK Optimus™ GX PRO 8100 SSD
Shop Now
SANDISK Optimus™ GX PRO 850X SSD
Shop Now
SANDISK Optimus™ GX 7100 SSD
Shop Now
Capacity2 1TB, 2TB, 4TB, 8TB2 1TB, 2TB, 4TB, 8TB2 500GB, 1TB, 2TB, 4TB2
Interface PCIe® 5.0 PCIe® 4.0 PCIe® 4.0
Sequential Read1 (up to) 14,900MB/s1 7,300MB/s1 (1TB, 2TB, and 4TB models) 7,250MB/s1 (1TB and 2TB models)
Sequential Write1 (up to) 14,000MB/s1 (2TB and 4TB models) 6,600MB/s1 (2TB, 4TB, and 8TB models) 6,900MB/s1 (1TB and 2TB models)
Boost PC Performance for Daily Workload Demand
Experience fast everyday computing.
High‑performance internal SSDs help PCs feel more responsive by accelerating boot times, application launches, and file access. Keep up with intensive multitasking and modern software with fast, reliable performance.
Power through content creation workflows.
Designed for sustained performance, these SSDs support demanding tasks like photo and video editing, large file transfers, and creative applications that rely on fast, consistent throughput.
Performance that scales with your work.
With higher speeds and capacities than entry‑level storage, performance‑class SSDs are built to handle growing projects, heavier workloads, and evolving PC use over time.
Upgrade Your NAS with SSDs
Accelerate your NAS with flash storage.
Move beyond HDD limitations with NAS SSDs that offer lower latency and more responsive performance even under heavy, multi-user workloads. Support fast file sharing, multi-user virtual environments and video editing workflows, with capacity that scales alongside your data needs.
Engineered for 24/7 NAS systems.
Designed for always‑on environments, SSDs for NAS system can help tackle always-on workloads with reliability and endurance of up to 500units TBW (250GB2 model only)3 , supporting continuous reads and writes from multiple users without sacrificing consistency.
Help maximize performance across many NAS setups.
From hybrid systems that balance capacity and speed, to all-flash environments built for maximum throughput, NAS SSDs accelerate critical data and keep applications running smoothly for demanding workloads. SANDISK® NAS SSDs are also tested with many leading NAS systems for compatibility, helping make upgrades seamless.
Frequently Asked Questions About Internal SSDs
SSD lifespan is measured using endurance ratings such as TBW (terabytes written) and DWPD (drive writes per day). Most consumer SSDs are designed to last many years under typical workloads, with higher ratings supporting heavier write activity. Learn more about how long SSDs last.
Related Content
SOLUTIONS
Compare SSDs | Internal, External & Portable SSDs
Compare Portable & External SSDs
SOLUTIONS
SSD vs HDD
SOLUTIONS
NVMe SSDs
SSDs
NVMe vs SATA SSDs Explained: Speed, Performance & Storage
SSDs
SSDs - Sandisk Topics Hub
SSDS
How Long Do Solid State Drives (SSDs) Last?
SSDS
Next-Generation Portable SSDs Delivering Faster Performance
SSDS
SanDisk Desk Drive External SSD Storage
ACCESSORIES
Acronis True Image Download for SanDisk Desk Drive SSD
SSDS
What is a Solid State Drive (SSD)?
SSDS
QLC SSDs Data Storage Solutions
1. 1 MB/s = 1 million bytes per second. Based on internal testing; performance may vary depending upon host device, usage conditions, drive capacity, and other factors.
2. 1GB=1,000,000,000 bytes. 1TB=1,000,000,000,000 bytes. Actual user storage less.
3. 1 PBW (petabytes written) = 1,000 TBW (terabytes written). TBW (terabytes written) and/or PBW (petabytes written) values calculated using JEDEC client workload (JESD219) and vary by product capacity. MTTF = Mean Time To Failure based on internal testing using Telcordia™ stress part testing (Telcordia SR-332, GF, 25°C). MTTF is based on a sample population and is estimated by statistical measurements and acceleration algorithms. MTTF does not predict an individual drive’s reliability and does not constitute a warranty.
