SSD vs HDD: What Is the Difference?
While HDDs are great for larger capacities and long-term storage, solid state drives are great for building and upgrading computers, laptops, and gaming platforms, thanks to their potential for fast read/write speeds, low latency, and durability.
Explore the Difference Between SSDs and HDDs
SSDs are the future of data storage — especially NVMe™ SSDs. They’ll get you faster read/write speeds, lower latency, and more durability. While HDDs are great for larger capacities and long-term storage, solid state drives are great for building and upgrading computers, laptops, and gaming platforms.
Solid State Drive (SSD)
  • Ideal for low-latency applications
  • Uses NAND flash memory cells without moving parts
  • Great for rapid boot times and fast file access
Hard Disk Drive (HDD)
  • Good for long-term storage
  • Uses mechanical parts like spinning disks
  • Used for cost-effective, massive capacities
Upgrade Your Laptop or Desktop: SSD vs. HDD
If you're upgrading your computer's internal storage, choose an SSD to help prioritize speed, responsiveness, durability, and efficiency.
Make Your Computer Feel More Responsive
Upgrade from an HDD to an SSD to help reduce storage-related slowdowns when launching applications, opening files, and moving between everyday tasks.
Help Protect Your Storage from Everyday Bumps
HDDs rely on moving mechanical components that can be vulnerable to physical damage. With no moving parts, SSDs are suited to the bumps and movement that laptops experience every day.
FOR GAMING AND WORKFLOWS
FOR Creators & Pros
FOR Gaming
for PC GAMING
External SSD vs. External Hard Drive
Compared with some external hard drives, external SSDs give you fast file transfers, strong durability, and more portable storage.
Move Big Files Faster
Spend less time waiting when transferring photos, videos, games, and other large files. External SSDs offer fast read and write speeds, helping you move your content and get back to what you're doing.
Work Directly From Your Drive
Fast external SSD storage can help you access and work with large files without first moving everything to your computer, making it a strong fit for workflows like photo and video editing.
Take Your Storage on the Go
Without the spinning platters and mechanical components found in HDDs, some external SSDs can be smaller and lighter, giving you portable storage that's easier to carry between home, work, school, or wherever you're headed.
Ideal for Backups
How Much Can You Store on SSDs?
If you need fast, responsive, durable data storage, SSDs can be a great choice for you. Just make sure you’re getting the capacity you need, whether you’re a die-hard gamer, a creative pro, or building your next NAS system.
Drive Capacity Music or Video or Photos
500GB 125K 30 80K
1TB/1000GB 250K 60 160K
2TB/2000GB 500K 120 320K
4TB/4000GB 1M 240 640K
6TB/6000GB 1.5M 360 960k
8TB/8000GB 2M 480 1.28m
12TB/12000GB 3M 720 1.92m
Capacity by Media: values in the Music1, or Video2, or Photo3
3 columns reflect storage potential of only that media respectively, not multiple or all media columns combined.
Frequently Asked Questions
Yes, you can transfer files and your operating system from an HDD to an SSD. Be sure to follow optimal back up practices like the 3-2-1 backup plan before transferring files.
Related Content
SOLUTIONS
Compare SSDs | Internal, External & Portable SSDs
Compare Portable & External SSDs
SOLUTIONS
Internal SSDs for PCs and Laptops | NVMe & SATA Compatibility
SOLUTIONS
NVMe SSDs
SSDs
NVMe vs SATA SSDs Explained: Speed, Performance & Storage
SSDs
SSDs - Sandisk Topics Hub
SSDS
How Long Do Solid State Drives (SSDs) Last?
SSDS
Next-Generation Portable SSDs Delivering Faster Performance
SSDS
SanDisk Desk Drive External SSD Storage
ACCESSORIES
Acronis True Image Download for SanDisk Desk Drive SSD
SSDS
What is a Solid State Drive (SSD)?
SSDS
QLC SSDs Data Storage Solutions
1. Based on read speed, unless otherwise stated. 1 MB/s = 1 million bytes per second. Based on internal testing; performance may vary depending upon host device, usage conditions, drive capacity, and other factors.
3. The number of songs is based on a 3.5MB MP3 file. Examples of the number of songs that can be stored are provided for illustrative purposes only. Your results will vary based on content, file compression, file format, file size, host device, pre-loaded files, settings, software and other factors.
4. The number of hours for videos is based on the 1920x1080 Full HD @ 30fps, 145MB/min, DV format. Examples of the hours of video that can be stored are provided for illustrative purposes only. Your results will vary based on bit rate, content, file compression, file format, file size, host device, pre-loaded files, resolution, settings, software and other factors.
5. The number of photos is based on a 16MP, 5.5MB JPEG file. Examples of the number of photos that can be stored are provided for illustrative purposes only. Your results will vary based on resolution, content, file compression, file format, file size, host device, pre-loaded files, settings, software and other factors.
