$i18n{business.forBusiness}
Memory Cards for Photography, Video, and Creative Work
The right memory card depends on what you shoot, how you shoot, and the camera you use. Explore memory card recommendations, performance considerations, and practical guidance for photography and video workflows.
Digital Cameras
The best memory card depends on how you shoot and the type of camera you use. Choose your camera category to compare card formats, capacities, and performance recommendations.
Why Capacity Matters for DSLR Cameras
High-resolution photos, RAW image files, and video recordings can quickly consume storage space. Choosing a higher-capacity SD card can help reduce card swaps during shoots and provide more room for extended photography sessions.
BEST FOR Everyday photography
30-Day Money-Back Guarantee
BEST FOR OUTDOOR PHOTOGRAPHY
BEST FOR SPORTS PHOTOGRAPHY
Why Speed Matters for DSLR Cameras
Memory card speed can affect burst photography performance, image buffer clearing, and video recording capabilities. Faster cards are often recommended for action photography, RAW capture, and higher-resolution video.
BEST FOR event photography
BEST FOR Burst Mode
BEST FOR FAST TRANSFERS
Power Your Workflow With the Right Card
Explore Sandisk-tested SD and CFexpress cards matched to your camera for faster capture and a more reliable workflow.
$i18n{search.detailsExclusion}
Offer valid on qualifying products bought online through the Sandisk online store. Minimum $199 spend before taxes and shipping. Free gift with purchase quantities are limited to a maximum of 1 per customer. Offer is only valid while supplies last. This offer may not be combined, used in conjunction with or used in addition to any other promotion or offer. Retailers, Resellers and Distributors are excluded from this promotion. The offer is not applicable for any prior purchases and may not be available in all regions of the world. Delivery must be made within the contiguous United States, excluding addresses in Hawaii, Alaska, Puerto Rico and other U.S. territories. This promotion valid between November 19, 2026 and November 25, 2026. If you return the product(s) that qualified you for the free Sandisk Hoodie, free item will no longer be valid. If the qualifying product(s) are returned for a refund after the free Sandisk Hoodie has been used, the value of the free item will be deducted from any refund amount.
Why Capacity Matters for Mirrorless Cameras
Mirrorless cameras often produce larger RAW image files and higher-resolution video than older camera systems. Higher-capacity memory cards can help support longer shoots and larger creative projects.
BEST FOR FREQUENT SHOOTERS
BEST FOR COMMERCIAL SHOOTS
BEST FOR CONTENT CREATORS
BEST FOR FAST ACTION
BEST FOR RAW & BURST CApture
Built for the Moment You Capture
Storage designed to keep up with how photographers shoot, edit, and save.
Why Capacity Matters for Point-and-Shoot Cameras
Storage needs depend on how often you shoot, transfer files, and travel. Higher-capacity cards can reduce the need to swap cards or manage storage while you're on the go.
BEST FOR CASUAL PHOTOGRAPHY
BEST FOR TRAVEL PHOTOGRAPHY
BEST FOR LARGE PHOTO LIBRARies
Why Speed Matters for Point-and-Shoot Cameras
Point-and-shoot cameras are designed for convenient, everyday photography. Memory card speed can affect how quickly photos are saved, support continuous shooting, and help maintain smooth video recording.
BEST FOR CREATIVE PROJECTS
BEST FOR 6K2 Capture
BEST FOR 8K2 Capture
Why Capacity Matters for Medium Format Digital Cameras
Medium format cameras produce exceptionally large RAW files and place greater demands on storage. Prioritize high-capacity, high-performance memory cards that can support professional capture workflows.
BEST FOR High-Res Capture
BEST FOR COMMERCIAL PROJECTS
BEST FOR Continuous CAPTURE
Why Speed Matters for Medium Format Cameras
Large RAW files place greater demands on memory card performance. Faster sustained write speeds can help clear the camera buffer and keep high-resolution capture moving efficiently.
BEST FOR FIELD WORK
BEST FOR Frequent Pro Use
BEST FOR high-volume PRODUCTIONS
Looking for Gaming Storage?
Find recommendations for Nintendo Switch™, Nintendo Switch™ 2, Steam Deck, ROG Ally, microSD Express, and gaming storage solutions.
Drones & Action Cameras
Video resolution, recording length, and shooting style all influence which microSD card is right for your setup. Start with the factor that matters most to you.
Why Capacity Matters for Drone & Action Cameras
Large video files, longer flight sessions, and extended recording can quickly consume storage. Higher-capacity microSD cards can help reduce card changes and provide more room for footage.
BEST FOR HOBBYIST
BEST FOR Extended Recording
BEST FOR HIGH-VOLUME VIDEO
Why Speed Matters for Drone & Action Cameras
Video resolution, frame rate, and long-duration capture modes often determine speed requirements. Faster cards can help support 4K2 recording, slow-motion capture, and quicker file transfers.
BEST FOR ACTION CAMERAS
BEST FOR 4K2 VIDEO CAPTURE
BEST FOR HIGH-BITRATE VIDEO
Dash & Security Cameras
When a security event or driving incident occurs, footage is only valuable if it has been recorded and preserved. Guardian Series memory cards are designed for devices that record continuously, with high-endurance performance, broad camera compatibility, and support for high-resolution video recording.
Choosing the Right Memory Card for Dash Cams
Dash cams rely on continuous recording to capture important moments on the road. Choosing a high-endurance microSD card with the right capacity and write speed helps support consistent video recording and retain more footage before older recordings are overwritten. Recording resolution, driving frequency, and loop recording settings can also influence which memory card is right for your dash cam.
BEST FOR ON-ROAD RECORDING
Choosing the Right Memory Card for Security Cameras
Security cameras often record continuously, making storage capacity, write speed, and endurance important considerations. High-endurance microSD cards help support consistent video recording and longer footage retention before older recordings are overwritten. Camera resolution, recording frequency, and local storage requirements can also affect how much footage your security camera can retain.
BEST FOR 24/7 MONITORING
Phone & Tablet
Smartphone storage fills up quickly with photos, videos, apps, and downloads. Expanding storage with a microSD card up to 1TB1 can help keep more content available on your device without relying on cloud storage.
Why Expand Your Smartphone Storage?
Photos, videos, apps, and downloads can quickly fill your phone's available storage. For compatible Android smartphones, a microSD card provides additional space to store more content directly on your device. Expanding storage can also help you manage growing photo libraries, keep important files accessible, and download content for offline use without relying entirely on cloud storage.
BEST FOR SMARTPHONE STORAGE
Readers & Accessories
Memory cards are only part of the workflow. Readers and accessories can help speed up file transfers, simplify backups, and move photos and videos between devices more efficiently.
Readers & Accessories to Complete Your Workflow
From transferring files and backing up content to organizing and protecting memory cards, the right accessories can help simplify how you capture, manage, and store your content.
BEST FOR MICROSD CARDs
BEST FOR SD CARD TRANSFERS
BEST FOR MOBILE TRANSFERS
Frequently Asked Questions
A 256GB SD card can hold approximately 25,0003 photos at 10MB per image or 8,500 RAW photos at 30MB each. Actual capacity depends on image resolution, file format, and compression. Higher-resolution cameras and RAW photography typically require more storage per image.
SANDISK Extreme and SANDISK Extreme PRO memory cards offer different performance levels. Extreme cards are well suited for everyday photography, 4K video, and content creation, while Extreme PRO models offer higher-performance options for demanding workflows like RAW burst photography and professional video. Actual speeds vary by card model and interface.
A high-endurance microSD card is generally recommended for dash cams because continuous loop recording involves frequent writing and overwriting of footage. The SANDISK Dash Cam Card is designed for these workloads, supporting continuous recording and video capture up to 4K UHD. Always check your dash cam's compatibility and capacity requirements.
The speed required for 4K2 video depends on your camera's recording bitrate, frame rate, and video format. Many 4K recording modes use V30-rated cards, while higher-bitrate formats may require V60, V90, or CFexpress. Check your camera's minimum sustained write-speed requirements before choosing a memory card.
An SD card reader connects an SD memory card to a computer or compatible device, allowing you to access and transfer photos, videos, and other files. Readers are available for different formats, including SD, microSD, and CFexpress, with transfer speeds varying by interface and device compatibility.
Disclosures:
- 1GB=1,000,000,000 bytes. 1TB=1,000,000,000,000 bytes. Actual user storage less.
- Compatible device required. 4K (4096x2160), 6K (6144x3160), 8K (7680x4320) and 12K (12288 x 6480) video support may vary based upon host device, file attributes, usage conditions and other factors. See www.sandisk.com/HD.
- Compatible device required. Up to 100,000 photos for 1TB; 50,000 photos for 512GB; 25,000 photos for 256GB; 12,000 photos for 128GB; and 6,000 photos for 64GB. Approximations; results may vary based on host device, file attributes and other factors. For Photos: Based on a 30 MP JPEG image with an average file size of 8.4MB.
Select options
{{alertMessage}}
