Data Transfer & Charging Cables from SanDisk
Pair the right cables with the right devices to power your data storage workflow and transfer content as fast as possible, as confidently as possible.
Be Confident About Your Cables
When you pair the right cables, connectors, ports, and protocols, you canâ€Ķ
Transfer faster
Handle large volumes of data with confidence knowing you’re getting the fastest possible speeds between devices.
Upload the day’s raw footage
Transfer proxies between data storage and editing
Export massive 3D renderings
Multitask better
Demand more from your hardware by using the right cables to connect data storage drives, host devices, monitors, peripherals, and more.
Edit content directly from your NAS system
Manage data redundancy across your RAID drives
Archive complete backups of critical content
Charge quicker
Push your tech further with cables that are engineered to power devices safely and efficiently, so they perform their best.
Quickly charge portable devices up to 100W1
Support external drives with the correct amount of power
Fuel up your devices reliably with UL-certified components
How to Choose the Right Cables
SanDisk’s new color-coded system makes it easier to pair the right cable with your favorite devices.
Thunderbolt
USB
Power In
Questions about protocols?
Check out Thunderbolt vs. USB-C.
Cables for Thunderboltâ„Ē Devices
Get high-speed data transfer up to 40Gbps
Power your favorite devices up to 100W (20V/5A)
Enjoy backwards compatibility with USB generations that also use USB-Câ„Ē
In two sizes
High-Speed Thunderbolt 3 40Gbps Cable
Orange-cable-1
0.6ft – Short for:
For daisy-chaining stacked devices and charging for portable devices
Orange-cable-2
2.6ft – Longer for:
For daisy-chaining across workstations and power delivery for external drives
Cables for USB Devices
Get fast data transfer up to 20Gbps with USB 3.2 Gen2x2 interface
Power your favorite devices up to 60W (20V/3A)
Backwards compatible with previous USB-C generations like USB 3.1 and 3.0
In two sizes
High-Speed USB-C 20Gbps Cable
Blue-cable-1
1.6ft – Short for:
Shorter for connecting monitors and peripherals and charging for portable devices
Blue-cable-2
3.2ft – Longer for:
For connecting devices across workstations with power delivery for external drives
Cables for Power and Charging
Support USB-C power delivery up to 100W (20V/5A) for heavy-duty USB-C devices like external hard drives
Quickly charge USB Type-C devices like phones, tablets, and computer accessories
6.5ft
High-Powered Charging Cable for USB-C Devices
Green-cable-1
6.5ft Cable
For power delivery for external drives and charging portable devices across large workstations
Want to learn more about cables, ports, connectors, and protocols?
Thunderb-vs-USB-banner-mobile
1. Power delivery varies by cable. See product specifications for more information.
āđ€āļ›āļĢāļĩāļĒāļšāđ€āļ—āļĩāļĒāļš
